Fix spaCy transformer models, so that they work again (have been broken for a while). Probably worth backporting to 24.11 too.
NixOS:master
← danieldk:fix-spacy-models
opened 01:05PM - 17 Nov 24 UTC
Fix various issues with building spaCy models. The largest change is that spaCy … 3.7.x has switched to using `spacy-curated-transformers` for transformer models in place of `spacy-transformers`. This change adds `spacy-curated-transformers` along with its dependensies `curated-transformers` and `curated-tokenizers`.
Besides that, this PR makes some smaller changes to `spacy-models` to make all models build again:
- Transformer models now use `spacy-curated-transformers`.
- `sl_core_news_trf` requires `protobuf` and `sentencepiece`.
- `ja` models require `sudachipy` and `sudachidict-core`
- Loosen the `pkuseg` requirement for `zh` models (0.3 -> 1.0 does not have API changes).
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [25.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) Release notes)
Thanks a lot if you do!
This one already had a review, but stalled after integrating the proposed changes:
NixOS:master
← danieldk:outlines-0.1.4
opened 03:52PM - 19 Nov 24 UTC
Update to the latest version of outlines.
## Things done
- Built on pl… atform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
I have one approval from a non-maintainer. Just looking for a maintainer.
NixOS:master
← lafrenierejm:aws-codeartifact-proxy
opened 06:35AM - 28 Apr 23 UTC
###### Description of changes
From the [package's homepage](https://github.co… m/sktan/aws-codeartifact-proxy):
> An AWS code artifact proxy to allow unauthenticated read access to your code artifacts
###### Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] aarch64-darwin
- [23.05 Release Notes (or backporting 22.11 Release notes)](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#generating-2305-release-notes)
I have this one really blocked. It works but no one seems to be accepting it
NixOS:master
← tembleking:fix-sysdig-cli-scanner-parametrized-arguments
opened 03:36PM - 27 Aug 24 UTC
If `--iac` is passed as parameter, we cannot use th… e `--dbpath` option, or it fails.
If `--iac` is not passed as parameter, then we are in vulnerability scanning mode, and we need to pass `--dbpath`, or the program will try to download the dbpath in the same path as the binary. The binary is in the nix store though, and is not writable, so it will fail. Specifying `--dbpath` to `$HOME/.cache` is a workaround for this limitation.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
This one might be interesting for IME users:
NixOS:master
← 34j:enable-wayland-ime
opened 04:34AM - 24 Nov 24 UTC
^ Please summarise the changes you have done and explain why they are nece… ssary here ^
Closes #358368
Adds `--enable-wayland-ime` flag to all Electron packages that uses `NIXOS_OZONE_WL`
According to Fcitx 5 wiki, it seems it is always recommended to add `--enable-wayland-ime` or `--gtk-version=4` (which is only supported in chromium/chrome) flag when launching Electron apps to use text-input-v1. (https://fcitx-im.org/wiki/Using_Fcitx_5_on_Wayland#Chromium_.2F_Electron) See #358368 for further information.
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
```python
import re
from collections import defaultdict
from pathlib import Path
# for each nix file in the pkgs directory
for path in Path('pkgs').rglob('*.nix'):
txt = path.read_text()
# find NIXOS_OZONE_WL
# start_text = '''"\''${NIXOS_OZONE_WL:+\''${WAYLAND_DISPLAY:+'''
match = re.search(r'\${WAYLAND_DISPLAY\:\+(.+?)}}', txt)
if match:
if "--enable-wayland-ime" not in match.group(1):
print(path)
txt = txt.replace(match.group(1), match.group(1) + " --enable-wayland-ime")
path.write_text(txt)
Poscat
November 27, 2024, 1:40am
4885
NixOS:master
← poscat0x04:bump-coredns
opened 09:31PM - 26 Nov 24 UTC
## Changes
See the release note of coredns:
[1.11.4](https://github.com/cored… ns/coredns/releases/tag/v1.11.4)
[1.12.0](https://github.com/coredns/coredns/releases/tag/v1.12.0)
This PR also incorporates the change suggested by https://github.com/NixOS/nixpkgs/pull/310159 and adds me as a maintainer.
As such it closes https://github.com/NixOS/nixpkgs/pull/310159 and https://github.com/NixOS/nixpkgs/issues/307750
^ Please summarise the changes you have done and explain why they are necessary here ^
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Bump the version of coredns and fixes a bug.
Poscat
November 27, 2024, 1:42am
4887
NixOS:master
← poscat0x04:epson-bump
opened 06:38AM - 12 Jul 24 UTC
Routine update. Couldn't find source tarballs beside … the source rpm.
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Bump the version of epson-escpr
Majiir
November 28, 2024, 4:39pm
4888
I’ve been these two on my config for a year with no issues:
TomB
November 28, 2024, 5:59pm
4889
NixOS:master
← TRPB:feature/addInitialHashedPasswordFile
opened 08:23PM - 25 Nov 24 UTC
It's currently not possible to use agenix for secrets with an immutable filesyst… em because `hashedPasswordFile` does not work with `mutableUsers = false` and the password must be specified with `initialPassword`/`initialHashedPassword`
This PR adds an `initialHashedPasswordFile` option to match the `hashedPasswordFile` option which already exists.
There is some additional work to be done around `systemd.sysusers.enable = true` and false parity.
As shown by `nixos/tests/systemd-sysusers-immutable.nix` `hashedPasswordFile` works for immutable users whereas when not using systemd users `hashedPasswordFile` does not work and we'd need `initialHashedPasswordFile`.
I assume that's actually a bug in sysusers because it won't be possible to change the user's password in the next generation, though I don't fully understand the need for `initialHashedPassword` and `hashedPassword`.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Tested, as applicable:
an initialHashedPasswordFile
option, using agenix
to handle the password is currently not possible without exposing the contents to the nix store using builtins.readFile
