Ory Hydra, an open source identity and access proxy
NixOS:master ← camcalaquian:carl/init-ory-hydra
opened 10:36AM - 26 Mar 25 UTC
^ Please summarise the changes you have done and explain why they are nece… ssary here ^
## Things done
- Built on platform(s)
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [X] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [X] Tested basic functionality of all binary files (usually in `./result/bin/`)
- [25.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) Release notes)
Thanks a lot if you do!
An encryption library, also used in Vula
NixOS:master ← mightyiam:highctidh
opened 11:34AM - 29 Mar 25 UTC
^ Please summarise the changes you have done and explain why they are neces… sary here ^
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
bryango
March 30, 2025, 5:58am
5337
NixOS:master ← bryango:newt
opened 04:14AM - 28 Feb 25 UTC
The python module "snack" (packaged along with "newt") has been [failing on darw… in](https://hydra.nixos.org/build/289850022/nixlog/1) (the job succeeds but the python c extension fails to be built and is simply absent). This causes commands that relies on `python3Packages.snack` to fail, e.g. byobu-config from the byobu package.
This patch uses some linker magic borrowed from https://github.com/NixOS/nixpkgs/blob/f61bd35c9f3711d85a39a1acffb3f85d2f521e1d/pkgs/by-name/sp/spade/package.nix#L55 to fix the issue.
This patch only changes the derivation hash on darwin; it should cause zero rebuild on linux. There are 3 commits:
1. move to by-name and adopt the package
2. clean up and explicitly add gettext for clang on darwin
3. fix python module (c extensions) with some linker magic
4. **(new)** add a (nonblocking) pythonImportsCheck to passthru.tests
5. **(new)** fix up the dylib names in _snack (bug revealed by the previous test)
^ Please summarise the changes you have done and explain why they are necessary here ^
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [x] x86_64-darwin
- [x] aarch64-darwin
- [x] `sandbox = true`
The python module “snack” (packaged along with “newt”) has been failing on darwin (the job succeeds but the python c extension fails to be built and is simply absent). This causes commands that relies on python3Packages.snack to fail, e.g. byobu-config from the byobu package. This PR fixes the issue.
osbm
March 30, 2025, 6:35pm
5339
Hello everyone, I have 3 PRs. 2 of them are package updates ( i am the maintainer of those packages)
NixOS:master ← osbm:update-datasets-3.5.0
opened 10:34AM - 28 Mar 25 UTC
## Things done
Updated the package
Changelog: https://github.com/huggingface/datasets/releases/tag/3.5.0
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
and
NixOS:master ← osbm:update-ultralytics
opened 10:39AM - 28 Mar 25 UTC
## Things done
Updated the ultralytics python package.
Changelog: https://github.com/ultralytics/ultralytics/releases/tag/v8.3.97
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
And my third PR is actually a bugfix (testing phase of this package hangs)
NixOS:master ← osbm:fix-albumentations
opened 04:25PM - 28 Mar 25 UTC
## Things done
I disabled a test that caused the build of this package to han… g during the testing phase.
I think this issue is also responsible for the build error on the hydra https://hydra.nixos.org/build/293674374
But the issue may not be fully reproducible for other machines. There is no error message and i dont know what causes this issue. So i just disabled the test.
Maintainers: @natsukium
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
c4f3z1n
March 31, 2025, 8:07am
5340
Added myself as a maintainer of GNU Rush and fixed a detail that caused a warning to pop up.
NixOS:master ← C4F3Z1N:tmp.k8Of4KWT3K
opened 03:02PM - 26 Mar 25 UTC
Added myself as a maintainer for GNU Rush and fixed the warning caused by runnin… g `lib.getExe` with it.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Packaged mango3d’s lychee slicer
NixOS:master ← ShyAssassin:lycheeslicer
opened 11:42PM - 24 Mar 25 UTC
Package mango3d's lychee slicer
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
