NixOS:master ← nevivurn:feat/update-kubelogin-oidc
opened 04:23PM - 29 Mar 25 UTC
^ Please summarise the changes you have done and explain why they are nece… ssary here ^
- Upstream bumped their go.mod go version, breaking r-ryantm.
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [25.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) Release notes)
Thanks a lot if you do!
NixOS:master ← nevivurn:feat/update-kavita
opened 04:08PM - 29 Mar 25 UTC
- Bumped dotnet, needs 9.0 since 0.8.5
- Ran the update script
- No dropped migrations in `git diff v0.8.4.2..v0.8.5.11 API/Startup.cs`
- Discovered a minor upstream issue affecting our tests, added patch
- Upstreamed fixes in Kareadita/Kavita#3686
- cc @benediktahle
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Tested, as applicable:
NixOS:master ← nevivurn:feat/kavita-user-fix
opened 01:31PM - 02 Nov 24 UTC
- Fixes #350600
- Also add myself to the module maintainers list
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
mostly simple bumps and a minor module user fix
I posted this before but it didn’t get any attention.
NixOS:master ← stusmall:add-amf-option-for-handbrake
opened 05:04PM - 06 Mar 25 UTC
This allows accelerated encoding with AMD graphics cards. This feature relies o… n a proprietary SDK so is disabled by default.
^ Please summarise the changes you have done and explain why they are necessary here ^
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
bouk
April 8, 2025, 5:45am
5366
NixOS:master ← bouk:bouk/otelcol-validate2
opened 12:17PM - 24 Mar 25 UTC
Just like we do for Nginx, we can validate the configuration of opentelemetry-collector during the build to avoid mistakes.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Someone already reviewed it, just needs someone with commit access
Svenum
April 8, 2025, 6:58am
5368
Here is another one, adding the fw-fanctrl module and package. (Framework Fanctonrol):
NixOS:master ← Svenum:add-fw-fanctrl
opened 07:48PM - 09 Mar 25 UTC
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] `sandbox = true`
- [x] (Module addition) Added a release notes entry if adding a new NixOS module
Umami analytics (package, module and tests):
NixOS:master ← diogotcorreia:umami-init
opened 01:05AM - 08 Feb 25 UTC
Add Umami (closes #172063)
I've taken the same approach as @jlesquembre, but … improved on it to run migrations automatically when Umami is started. I've also solved the problem with upstream making HTTP requests to get GeoCities during the build process by pinning it to a specific revision when updating (see update script).
As for some pesky details:
- Umami needs the database variant to be defined at build time since it uses different schema definitions for postgres and mysql, so I make it an argument to the derivation, which is override-able from a future module.
- Likewise, the environment variables `COLLECT_API_ENDPOINT` and `TRACKER_SCRIPT_NAME` pose a challenge as they are read during build time. Upstream's docker image goes around this by adding a [middleware file](https://github.com/umami-software/umami/blob/v2.15.1/docker/middleware.js) for this to happen at runtime, but I decided against that since it would (slightly) reduce performance, it doesn't take that long to rebuild umami (~2 min on my laptop), and it probably is a niche feature. Additionally, if done at runtime, setting `COLLECT_API_ENDPOINT` would require changing a file in the derivation, so we would have to perform some hacks to do that.
- While I've tested the PostgreSQL variant successfully, ~~I could not test MySQL~~ since I used MariaDB and there seems to be an [upstream issue with one of the migrations](https://github.com/umami-software/umami/issues/2645). ~~I might try again in the next few days.~~ **EDIT:** MySQL works fine; MariaDB doesn't, but that's a problem upstream.
Example to override build arguments:
```nix
pkgs.umami.override {
databaseType = "mysql";
collectApiEndpoint = "/api/alternate-send",
trackerScriptNames = [ "tracker.js" "tracker2.js" ],
I've tested this with a clean database (PostgreSQL) and **it seems to work perfectly**. I will try it in my production deployment in the next few days and perhaps do a module as well. **EDIT:** Has been in production for a while, working fine.
Previous attempts (pinging relevant people so they can chime in):
Closes #371889 @elikoga @GiggleSquid
Closes #372220 @jlesquembre
Feedback/testing is very much appreciated. In theory, the only thing necessary to run this is to set `DATABASE_URL` and then run `result/bin/umami-server`.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Pairdrop (module and tests):
NixOS:master ← diogotcorreia:module-pairdrop
opened 07:04PM - 02 Feb 25 UTC
Add new module and tests for [PairDrop](https://github.com/schlagmichdoch/pairdr… op).
~~To be merged after #378874 (that's the only reason this one is draft at the moment), otherwise tests will fail.~~ **EDIT:** has been merged
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Linkwarden. Contains package, nixos module and tests. Despite being on the first page of PRs without merge conflicts if sorted by upvotes, still no review from someone that can merge it
NixOS:master ← jvanbruegge:linkwarden
opened 09:31PM - 08 Oct 24 UTC
Linkwarden is a self-hosted bookmarks manager: https://linkwarden.app/
## Thi… ngs done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
I’d love to see this get merged (specifically for vl-convert-python)!
This is a fix that should’ve been merged by a few weeks ago
NixOS:master ← hustlerone:master
opened 02:18PM - 20 Mar 25 UTC
## Things done
Adjusted the systemd unit for kmscon to fix https://github.com/NixOS/nixpkgs/issues/385497
This however will completely disable DRM for kmscon and now seats will be unspecified.
If someone absolutely requires DRM for kmscon, let me know.
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [X] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md).
relaze
April 9, 2025, 3:54pm
5375
4 months old PR, instrumental for ags and astal:
NixOS:master ← PerchunPak:vala-panel-appmenu-init
opened 01:13PM - 16 Jan 25 UTC
https://gitlab.com/vala-panel-project/vala-panel-appmenu: Global Menu for Vala Panel/XFCE/Budgie/Mate
This is required for `astal.tray`
https://github.com/NixOS/nixpkgs/blob/ffeebf0acf3ae8b29f8c7049cd911b9636efd7e7/pkgs/development/libraries/astal/modules/tray.nix#L9
Closes https://github.com/NixOS/nixpkgs/issues/337630
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
