Eval warning about (breaking) scudo settings migration in 25.11, would appreciate a review!
master ← NoRePercussions:norepercussions/push-pyuomsnvsozu
opened 01:38AM - 27 Dec 25 UTC
NixOS 25.11 uses standalone Scudo for the first time (85b124c). With this change… , options are now snake_case instead of CamelCase.
https://llvm.org/docs/ScudoHardenedAllocator.html#options
There is currently no breaking-change warning or evaluation warning to alert users of this change. As a consequence, users may leave old options and run into scudo's runtime warnings. This adds a straightforward evaluation-time warning if an old-style option is detected.
Relevant issue: https://github.com/NixOS/nixpkgs/issues/437368
Relevant PR: https://github.com/NixOS/nixpkgs/pull/444605
## Things done
Add a warning when the Scudo allocator is enabled and old-style Scudo options are passed.
- Built on platform:
- [ ] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
- [x] aarch64-darwin
- Tested, as applicable:
- [x] Tested basic functionality ~~of all binary files, usually in `./result/bin/`~~.
- Nixpkgs Release Notes
- NixOS Release Notes
First-time contribution, fairly minor
master ← emily-lavender:add-deps-fnl
opened 06:25PM - 28 Jan 26 UTC
Added `deps.fnl`, a dependency manager for the Fennel language. `luaPackages.fen… nel`, `fennel-ls`, and `fnlfmt` are already in nixpkgs, so this allows for a more complete Fennel dev environment. Since deps invokes its own argv0 to run fennel commands, the shebang needs to point directly to the fennel lua script rather than the luarocks wrapper. This is fine, since fennel is running as a standalone package.
https://gitlab.com/andreyorst/deps.fnl
## Things done
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [X] Tested basic functionality of all binary files, usually in `./result/bin/`.
- [X] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
ilkecan
February 3, 2026, 7:19am
6361
The author of the PR is the upstream developer. They added themselves as a maintainer, since the package had none. I have built and verified the package is working.
master ← txn2:kubefwd-1.25.8
opened 02:07AM - 04 Jan 26 UTC
Update kubefwd from 1.22.5 to 1.25.9.
**Changes in this update:**
- Fixed `r… ev` pattern: tags changed from `1.x.x` to `v1.x.x` format
- Updated homepage to https://kubefwd.com
**Release notes:** https://github.com/txn2/kubefwd/releases/tag/v1.25.8
**Highlights since 1.22.5:**
- Interactive TUI mode with real-time service monitoring
- Auto-reconnect with exponential backoff
- Windows hosts path auto-detection
- MCP (Model Context Protocol) server support
- HTTP traffic inspection
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [x] x86_64-darwin
- [ ] Tested basic functionality of all binary files, usually in `./result/bin/`.
master ← jerith666:calibre-8-16-2
opened 01:16AM - 13 Jan 26 UTC
fixes #478298
## Things done
- [x] x86_6… 4-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
It’s a bit behind but it fixes the build and will unblock r-ryantm
Simple version upgrade that fixes bugs that make it unusable.
master ← brianmay:modemmanager_update
opened 10:10PM - 13 Dec 25 UTC
Theory is this should fix #469173. Although having problems testing (nix wants t… o rebuild a lot unrelated stuff and is failing to do so). Still trying to work this out.
## Things done
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
master ← rafaelrc7:newlib-i686/fix
opened 05:32AM - 28 Dec 25 UTC
Fixes #424403
Fixes #404741
This PR adds a patch of upstream commits that fi… x the build with gcc-14.
In addition to `nixpkgs-review` (result posted below), I also successfully built `pkgsCross.i686-embedded.buildPackages.binutils`, `pkgsCross.i686-embedded.buildPackages.gcc` and `pkgsCross.i686-embedded.newlib`.
I also added the auto backport to 25.11 label as this build failure also affects the current stable branch.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
Fix of a build failure for cross-compiling to i686.
I also have a new package and a small change adding myself to a package.
master ← rafaelrc7:golazo
opened 06:06AM - 03 Feb 26 UTC
https://github.com/0xjuanma/golazo
A TUI app written in go to follow football… matches in real time.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
master ← rafaelrc7:irpf/maintainer
opened 06:38AM - 03 Feb 26 UTC
Tax time is getting close :(
## Things done
- … [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
All are ready for reviews and I would appreciate a lot, specially with the first one.
master ← nicegamer7:update-ente-web
opened 06:31PM - 22 Jan 26 UTC
Rust code was added in the v1.2.28 release, so this package has not been updatin… g automatically since then. I updated the package definition so that it builds, but I'm not sure how exactly to test it. I use the Ente module on a VPS. If anyone has an idea on how to test this using the Ente module, let me know and I'll do that.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] [NixOS tests] in [nixos/tests].
Just a simple package bump. The maintainers don’t seem active, so I’ve added myself as a maintainer. I use this package personally, so I will keep it up to date.
